Not trying to blow you off, but the amount of information you will need is much too large to post here. I strongly recommend you buy a "good" service and repair manual. You'll find it'll be the best money you've ever spent. There are issues with cleaning, gasket choices, torque specs, etc. That are a must, Also, if you're like me, you can't remember it all. So you will need to back to the book for reference.
My personal opinion. Don't waste your money on a Chilton, Haynes or any of the "cheapies". They'll tell you just enough to get you in trouble, and you don't want to have to do it all over again in a couple of months. Get the best one you can. You won't regret it. We handle the Mitchell line at this site, which also is our moderator reference system, but Motors is another good one.
What you have is a "common" problem with GM intake manifolds. There is a new gasket available to compensate for it. Be sure the gasket you select is the upgraded unit and not the OEM. I believe most dealerships are using the new one. Hope this helps.
SPONSORED LINKS
Monday, April 13th, 2009 AT 1:20 PM
