HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Lumina
Engine Cooling
Radiator
Leak
SPONSORED LINKS
1998 Chevy Lumina Radiator
IMJBIRD2
MEMBER
1998 CHEVROLET LUMINA
6 CYL
FWD
AUTOMATIC
57,000 MILES
It was low on coolant, could that possibly a leak somewhere?
Wednesday, May 27th, 2009 AT 3:58 PM
MECHANIC
Hi there,
Get a cooling system pressure test done, this will locate any external coolant leaks. Start here.
Mark (mhpautos)
SPONSORED LINKS
Thursday, May 28th, 2009 AT 12:41 AM
IMJBIRD2
MEMBER
The information was very helpful.
Thank You,
Jay
Thursday, May 28th, 2009 AT 11:25 AM
Please
login
or
register
to post a reply.
Related Radiator Leak Content
Radiator Leaking
I Have A 1995 Chevy Lumina With A 3.1l 6cyl Engine. The Radiator Is Leaking Fluid From The Bottom. If You Look Under The Car There Are Two...
Asked by
lestratman
1 ANSWER
CHEVROLET LUMINA
1998 Chevy Lumina I Am Baffled
Engine Cooling Problem 1998 Chevy Lumina 6 Cyl Front Wheel Drive Automatic My Car Is Overheating. I Have Replaced The Water Pump, I...
Asked by
faqdwrld1
1998
CHEVROLET LUMINA
How To Remove A Radiator On A 1998 Lumina
Asked by
evalder
1 ANSWER
1998
CHEVROLET LUMINA
Lumina Radiator Drain Valve
2000 Lumina, 72000 Miles I Found The Drain Valve Thanks To Comments On This Site. Does The Valve Unscrew Or Just Pull Out? It Is On...
Asked by
pastormrg
1 ANSWER
CHEVROLET LUMINA
1997 Chevy Lumina Water In Radiator
I Just Got My Oil Changed, And Was Told That The Mechanic Is Referring Me To The Dealer Or A Radiator Shop. Said There Is Oil In The...
Asked by
blondie42550
1997
CHEVROLET LUMINA
VIEW MORE
SPONSORED LINKS
Radiator Replacement Mercedes Benz
Online car repair manuals
