1995 Chevrolet Lumina Radiator Leak
LESTRATMAN
I have a 1995 chevy lumina with a 3.1L 6cyl engine. The radiator is leaking fluid from the bottom...If you look under the car there are two rubber stoppers at the bottom of the radiator....one on the driver side and one on the passenger side....The one on the passenger side is fine...the one on the driver side is gone though....like its busted....Is there a way to just replace that instead of buying an entirely new radiator? and if so what is that part called?
Mar 14, 2007 at 4:20 AM
2CARPRO JACK
  • 11,533 POSTS
Yes you can buy the tanks but..... If the tank broke the other side is probably just as weak, they are only plastic and aluminum. I would opt for a new one and forget about it
Mar 15, 2007 at 1:14 AM
Suggested Repair
Replace the radiator rather than only the missing drain plug or tank. The plastic tanks are likely weak on both sides.
Conversation Summary
The owner of a 1995 Chevrolet Lumina 3.1L reports coolant leaking from the bottom of the radiator where the driver-side rubber stopper is missing or broken, and asks whether that part can be replaced alone. The expert says radiator tanks can be purchased, but recommends a new radiator because the plastic and aluminum tanks are likely weak on both sides.
