My car does not start after sitting over night. I have to jump it then it is fine for the rest of the day. Just got new battery, starter, and alternator. Cant figure it out!
Friday, February 22nd, 2008 AT 7:53 PM
BMRFIXIT
MECHANIC
Have to do a draw test
u can use a test light for that
disconnect negative side of the battery and connect the test light in between if it lights up bright you have a draw
start pulling fuses until light fade down
this is the circuit that have a draw on it
check what that fuse control make sure the all off
good luck
