1997 Chevy Lumina Car start but quits running
CBLACK3927
  • 1997 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 173,000 MILES
Have replaced the alternator and the battery but it seems the alternator was not charging the battery. Replaced the alternator a second time and still does not charge it. Runs until battery low on charge and then quits running until recharge of battery.
Friday, September 25th, 2009 AT 10:40 AM
JDL
  • 16,098 POSTS
I'd use a digital multimeter to check. Take reading across battery posts, everything turned off. A fully charged battery will show around 12.6 volts. Take another reading at the battery posts, engine running, the second reading should be higher than the first, if it isn't, take a reading at the bat terminal at the alternator, if that reading is higher, then there is something wrong with the wiring circuit between the alternator and battery.
Friday, September 25th, 2009 AT 4:16 PM
