1997 Chevy Lumina Car stutters then Dies
JINDENVER
  • 1997 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 104,500 MILES
My Lumina when I start it up runs rough and when I put it into gear it begins to stutter and then just dies out as if it is not getting any gas.
When it stalls out I try to restart it but it attempts to start but appears to not get any fuel to the engine.
This only happens every so often, maybe once every 2 weeks.
The car after sitting for about an hour starts right up and runs fine til the next time it decides to stall out.
I can not get the car to produce the problem for local mechanics and they have tested the fuel pump.
What could the problem be?
Saturday, June 7th, 2008 AT 7:57 AM
MERLIN2021
  • 17,250 POSTS
Have you done a relearn on the pass-key?
GM PASS LOCK RELEARN- Ignition to "run" position, try to start and let key return to "run" position
Approx ten minutes security light will go off
Turn key "off" and wait 5 seconds
Repeat 2 more times for a total of 3 relearns.
Turn key off, then start it
Saturday, June 7th, 2008 AT 8:01 AM
