VAN WILL NOT START?
SW123MAN
  • 1995 CHEVROLET LUMINA
Electrical problem
1995 Chevy Lumina V6 Two Wheel Drive Automatic 250000 miles
The battery was just replaced and the dash light up for a second but then nothing. What is the problem? There is nothing when I turn the key. Ignition coil maybe.
Saturday, December 8th, 2007 AT 3:45 PM
BLACKOP555
  • 10,371 POSTS
Did you hook up the battery right? Sounds to me that your ignition switch is no more good. Check for fuses first.
Saturday, December 8th, 2007 AT 6:02 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,690 POSTS
This is common, one of the battery terminals is loose which was not installed correctly when the new battery put in. Here is a guide that will help you fix it.
Please go over this guide and get back to us.
Monday, July 22nd, 2024 AT 2:18 PM
