1995 Chevy Lumina car will not start
YATES2005
  • 1995 CHEVROLET LUMINA
Engine Mechanical problem
1995 Chevy Lumina 6 cyl Front Wheel Drive Automatic
have full elec. Power lights radio new battery and have check the fuses but the starter will not turn over
Monday, March 2nd, 2009 AT 7:50 AM
JDL
  • 16,098 POSTS
Do you have a theft system? Have you tried cranking in neutral? You may have to do some testing at the starter solenoid. Make sure the tranny is in park or neutral during testing. If the starter field terminal is hot, with the key in the crank position and the grounds are good and the starter isn't pulling anything, may be something wrong with the starter?
Monday, March 2nd, 2009 AT 8:21 AM
YATES2005
We have tried it in nutrual and end park there is power going to the starter
Monday, March 2nd, 2009 AT 8:27 AM
JDL
  • 16,098 POSTS
There is a smaller wire at the starter solenoid, usually purple, that wire should be hot, with the key in the crank position.
Monday, March 2nd, 2009 AT 10:18 AM
