1995 Chevy Lumina head gasket! Hydrocarbons found
GLUCOSEMETER
  • 1995 CHEVROLET LUMINA
  • 6 CYL
  • 150,000 MILES
I have a 95 and it got really hot one day. The dealer said they detected hydrocarbons in coolant. Now when I start it from cold, 8 mins later it goes into the red and over fills the resavoir while there is no heat coming out of heater.
Sunday, October 5th, 2008 AT 7:40 PM
  • 109,885 POSTS
Hi:
Did the heater work prior to the overheat? Also, did you check the T-stat, waterpump, radiator, and hoses? I have seen the lower rad hose collapse causing the vehicle to over heat. Also, if there is no heat and it worked before, there is a problem with the coolant making it to the heater core. Check hoses for heat. Also, make sure the cooling fans are turning on.
Tuesday, October 14th, 2008 AT 10:40 AM
RENAUDTN
  • 636 POSTS
If the dealer found gas in your coolant, you may have a blown head gasket.
On top of what Jacobandnickolas told you, you should get that checked as well.
Tuesday, October 14th, 2008 AT 2:22 PM
