1995 Chevy Lumina Brake Lights
TWOO46
  • 1995 CHEVROLET LUMINA
  • 6 CYL
  • 14,400 MILES
I have a 1995 Chev Lumina, the problem is my outside brake light does not work I tried the bulb, fuses and brake light switch with no luck. The brake light in the back window come on when I apply the brakes, but none of the outside break light come on. The rear light work when I turn on the headlight, but when the break is applied they do not come on. Thanks
Tuesday, April 14th, 2009 AT 10:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Test wiring to brake light switch to ensure it is getting power when needed. Make sure brake switch is adjusted properly as well.
Tuesday, April 14th, 2009 AT 12:14 PM
TWOO46
I test the wiring, OK
I adjusted the break light switch, OK.
I test the fuses, Ok
The outside break light do not work, can you help?
Friday, April 17th, 2009 AT 8:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
If all is OK that you mentioned then inspect mult-function switch. Is on same circuit, if it is faulty it will cause this symptom.
Thanks for using 2CarPros. Com!
Friday, April 17th, 2009 AT 4:46 PM
