Thank you so much for your time I am an out of work injured worker and this is costing me so much so your input is greatly appreciated, so again thank you. I ahve replaced the fuel pump, fuel pressure regulator, fuel filter, fuel relay. Then the ignition control module, coil packs, plug wires, crank sensor, tps, iac, ecu, fuses, fusable links, egr valve, I even dropped the exhaust thinking the cat might be plugged. I am at a total loss its like it gets gas to start then something tells it not to give more gas. I have 46lbs. Of fuel pressure. So I just dont get it. Again thank you for your time.
SPONSORED LINKS
Sunday, May 18th, 2008 AT 2:20 PM
