Engine Performance problem
1991 Chevy Lumina 6 cyl Front Wheel Drive Automatic
Why does my 3.1 port fuel injected car bog out when you go hit on the gas?
Sunday, May 18th, 2008 AT 11:49 PM
MECHANIC
Hi there,
Start with a scan test, checking for a possible problem with a TPI sensor, also check fuel pump pressure and flow rate, get a fuel rail pressure test done, start here.
Mark (mhpautos)
SPONSORED LINKS
Sunday, May 18th, 2008 AT 11:58 PM
BADBOYZDERBY
MEMBER
What are the ratings for the fuel pump pressure, flow rate, and fuel rail pressure? What is the TPI because I think I put a new one in?
Monday, May 19th, 2008 AT 12:08 AM
MECHANIC
Hi there,
The TPI, is the throttle position indicator or sensor, located at the throttle body, as for the fuel pressures& flow rates, I will have to re post as I don't have access to that info on this computer.
Mark (mhpautos)
Monday, May 19th, 2008 AT 12:14 AM
BADBOYZDERBY
MEMBER
I already change the TPI
Monday, May 19th, 2008 AT 12:18 AM
MECHANIC
Hi there,
OK, have you done a scan, just in case there is a fault code logged. And check the usual things, if you have not already, fuel filter, all tune items, vacuum leaks.
Mark (mhpautos)
SPONSORED LINKS
Monday, May 19th, 2008 AT 12:23 AM
BADBOYZDERBY
MEMBER
There is no faulty code, their is no fuel filter any more but it ran fine with out one, I have some new plugs but I did just one side and I cant seem to find a vaccum leak but I will try to see if I can find one what is the best way to find a vacumm leak
Monday, May 19th, 2008 AT 12:28 AM
MECHANIC
It's a bit of a worry that you're not running a fuel filter, the injectors may be affected with all the muck in the fuel, you will be surprised how much rubbish your filter will catch. To check for a vacuum leak, you can use a length of hose and use it as a stereoscope and listen around the manifold gaskets and vacuum ports, you should hear a leak.
