1993 Chevy Lumina 1993 Chevy Lumina
MHSBLACK
1993 Chevy Lumina 6 cyl Front Wheel Drive Automatic
Other than the iddle control what would cause the engine to race when you start it?
Apr 13, 2009 at 8:52 AM
LEGITIMATE007
  • 5,121 POSTS
a damaged or unhooked vacuum hose somewhere near the intake, also the throttle plate could be gummed up so you will want to clean it also
Apr 13, 2009 at 9:46 AM
MHSBLACK
[quote:1b6f70dd51="legitimate007"]a damaged or unhooked vacuum hose somewhere near the intake, also the throttle plate could be gummed up so you will want to clean it also[/quote:1b6f70dd51]
I did what you suggested and it did not fix the problem. Any other suggestions?
Apr 23, 2009 at 12:44 AM
LEGITIMATE007
  • 5,121 POSTS
next you'll want to check the throttle position sensor, it could be faulty, then fuel pressure, , then go to your engine coolant temp sensor, this is the thing with sensors, several of them could be the problem in any combination too.
Apr 23, 2009 at 2:20 AM
LEGITIMATE007
  • 5,121 POSTS
