I turn the key and the car starts, but when I let go of the key it shuts off?
Tuesday, July 14th, 2009 AT 9:43 PM
MECHANIC
Check for power at the coil before you start the vehicle and when it dies out leave the key in on position and check again. Do you have power to the coil? If not test the ignition switch.
