1990 Chevy Lumina Please Help!!!
158,892 MILES • 6 CYL • FWD • AUTOMATIC
JESSICA0612
Im in need of help. I dont know what else to do. I can start my car fine, but as soon as i give it gas it stalls out. I have chnged the coil pac, the spark plugs, the fuel filter, and i even drained the gas out to see if there was anything in it. But I can not get it to stay running. Please help me. Thank you.
Jul 17, 2009 at 3:04 AM
JDL
  • 16,098 POSTS
Hello, will the vehicle idle in drive? Are there any trouble-codes? Use a gage and check fuel pressure.
https://images.2carpros.com/forum/automotive_pictures/170934_aldl_19.jpg
to check for codes, use a jumper between the A & B terminals of the datalink connector, turn the key on, no crank, then the check engine lite starts to flash, you count the flashes to get the codes.
Jul 17, 2009 at 3:17 AM
