2001 Chevrolet Impala Brake Vibration
MURPHYSLAW5
Chev Impala 2001, 146K Miles, 3.8L V6
New tires, newly aligned, new brake pads....
There is a strong vibration in the sterring wheel during moderate to strong braking. Light application of brakes does not cause vibration.
Oct 10, 2007 at 10:17 AM
MERLIN2021
  • 17,250 POSTS
Rotors need to be Turned or replaced!
Oct 10, 2007 at 10:20 AM
MURPHYSLAW5
turned v replaced....leaning toward replace?
Oct 10, 2007 at 10:32 AM
Suggested Repair
Have the brake rotors turned or replaced. With strong steering-wheel vibration under moderate to hard braking and 146,000 miles, replacement is often the better choice if the rotors are warped, thin, or below minimum thickness.
Conversation Summary
A 2001 Chevrolet Impala with 146,000 miles vibrates strongly in the steering wheel during moderate to hard braking, but not during light braking. Tires, alignment, and brake pads are new. The expert said the rotors need to be turned or replaced, and the owner was leaning toward replacement.
