2004 Chevrolet Impala Brake Pulsation Fix
EDDIEORBIT
4 months ago, 2004 impala, (auto, front drive, 4 door, vortec V-6), started to vibrate when brakes were applied. Took it to Gdyear, they said brakes were fine. Took it later to Tir kng for A/C work, and they noticed the problem and suggested a brake job. I took it back to them, they did the brake job, and NO IMPROVEMENT. They have never encountered this problem. The brake job was a new pads, new hardware, resurface the rotors and test drive. They noticed no warp. (Great shop though, they charged me 0.00 for the brake job! What possible cause? no crash or known warn parts, I have regurally rotated and balanced the tires.
Any help?
Thanks ever so much. (Great forum by the way!)
Eddie
Jul 15, 2007 at 3:51 AM
BOOTDOG
  • 665 POSTS
if it still vibrates then the next step is replacing the rotors. all resurfacing does is reduce the life of the rotor and make it easier to warp later. replace the rotors with o.e.m. and the brakes should be fine.
Jul 15, 2007 at 7:47 AM
Suggested Repair
Replace the brake rotors with OEM rotors rather than resurfacing them. Resurfacing shortens rotor life and can make warping more likely.
Conversation Summary
A 2004 Chevrolet Impala vibrates when the brakes are applied. One shop found the brakes fine; another installed new pads and hardware and resurfaced the rotors, but the vibration remained and no warp was noted. The expert recommends replacing the rotors with OEM units instead of resurfacing.
