2003 Chevrolet Impala Brake Pulsation
176SUPERTECH
  • 5 POSTS
I have a 2003 Chevy Impala (53K miles) with a front brake problem. When I brake, the left front brake pulsates which can be felt in the brake pedal.The harder the brakes are applied, the more it pulsates. I have replaced the front pads and rotors, bled the brakes and replaced the front tires. None of these helped. Could it be the caliper or antilock brakes? The car stops OK and the brake pedal does not go to the floor.
Mar 7, 2006 at 9:40 AM
NOS
  • 320 POSTS
warped drums or rotors on the back may cause same problem. most generally if it is abs problem it will set abs light. (NOS
Mar 8, 2006 at 4:08 PM
Suggested Repair
Inspect the rear brake drums or rotors for warping, which can cause the same pedal pulsation. An ABS problem would generally turn on the ABS warning light.
Conversation Summary
A 2003 Chevrolet Impala owner reports left-front brake pulsation felt in the pedal that increases with harder braking. Front pads and rotors were replaced, the brakes were bled, and the front tires were replaced, with no improvement. The car stops normally and the pedal does not go to the floor. The expert says warped rear drums or rotors can cause the same symptom and that an ABS problem would generally set the ABS light.
