2001 Chevrolet Impala Battery Light
KIT71
I have a 2001 cheverlet Impala 3.8L with 133,000 miles. I have for the past year have had my battery indicater light flash on and off, a constat clicking noise under my dash that also causes my dash and radio displays to flicker. My radio display, dash lights, and my daytime running lights will dim then brighten. I have checked my alternater and have changed it 5 times. Please help, the dinging and clicking are starting to drive me mad and I don't have the money to take it to the mechanic who said just to check the system will cost $40 an hour.
Jul 31, 2007 at 1:54 AM
CLY
  • 308 POSTS
To run tests on your car for $40 an hour is cheap...
But the problem you are having sounds like a body control module going out. That is why all the lights an buzzing noises are going on. I have replaced several for complaints similar to yours...Another thing I would check is the fuse block under the hood. Make sure all connection are clean and tight.
Cly
Jul 31, 2007 at 8:56 AM
Suggested Repair
Suspect a failing body control module. Also inspect the underhood fuse block and make sure all connections are clean and tight.
Conversation Summary
A 2001 Chevrolet Impala 3.8L has an intermittent battery light, clicking under the dash, and flickering or dimming dash, radio, and daytime running lights despite five alternator replacements. The expert says the symptoms sound like a failing body control module and recommends checking that the underhood fuse block connections are clean and tight.
