2004 Chevrolet Impala Check Engine Light
ROSEMARY356
  • 6 POSTS
2004 impala 66,000 miles 6 cylinder
My engine light keeps coming on. I replaced the gas cap. I had auto zone run the codes and they said I had a leak?? They reset it after I replaced the gas cap and within 4 days it is back on. What else could it be?
Aug 19, 2007 at 10:30 PM
SERVICE WRITER
  • 9,123 POSTS
The evaporative system has various components that may be failing. However it may also be a simple as a hose that has become disconnected or leaking. There may be a valve stcking or the neck leaking. The car needs to go to a shop that is current with the techniques of diagnosing this code. It may involve injecting smoke into the system or using a scanner capable of remotely controling the valves associated with the evaporative system.
Aug 19, 2007 at 10:43 PM
ROSEMARY356
  • 6 POSTS
[quote:75a4fd3502="Service Writer"]The evaporative system has various components that may be failing. However it may also be a simple as a hose that has become disconnected or leaking. There may be a valve stcking or the neck leaking. The car needs to go to a shop that is current with the techniques of diagnosing this code. It may involve injecting smoke into the system or using a scanner capable of remotely controling the valves associated with the evaporative system.[/quote:75a4fd3502]
Thank you very much, I will call today for an appointment :D
Aug 19, 2007 at 10:51 PM
ROSEMARY356
  • 6 POSTS
[quote:e459bb981c="Service Writer"]The evaporative system has various components that may be failing. However it may also be a simple as a hose that has become disconnected or leaking. There may be a valve stcking or the neck leaking. The car needs to go to a shop that is current with the techniques of diagnosing this code. It may involve injecting smoke into the system or using a scanner capable of remotely controling the valves associated with the evaporative system.[/quote:e459bb981c]
Aug 19, 2007 at 10:59 PM
Suggested Repair
Have a shop diagnose the evaporative emissions system. Check for a disconnected or leaking hose, a sticking valve, or a leaking filler neck, using a smoke test or a scanner that can command the EVAP valves.
Conversation Summary
The owner of a 2004 Chevrolet Impala with 66,000 miles reported a recurring check engine light. A gas cap replacement and code reset did not fix it, and AutoZone indicated a leak. The expert said the EVAP system may have a failed component, disconnected or leaking hose, sticking valve, or leaking neck, and recommended professional diagnosis with smoke testing or a scanner that can control the EVAP valves. The owner planned to schedule an appointment.
