F150 Ball Joints
CBSONGMAN
I have a 98 F150 with 85000 mi. My question is what would be considered a normal time frame for replacing front ball joints and tie rods under normal driving conditions?
Jan 5, 2006 at 4:21 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Request an inspection using the correct wear-check procedure and limits for the installed suspension. Base replacement on documented condition rather than the other vehicles' mileages.
Guidance references and applicability
Source: This question and its visible discussion. The roadmap distinguishes the original owner's reports from other participants' experiences; proposed follow-up is editorial guidance, not a confirmed diagnosis. MOOG: Ball joint inspection procedure https://www.moogparts.com/content/dam/marketing/North-America/moog/pdf/did-you-know/english/DYK09_103_En.pdf Dodge-van example illustrating why inspection depends on joint design; its procedure and limits are not F-150 specifications.
Read the replies · Discussion summary and reported outcome
SMOKINFLOYD4.3
  • 56 POSTS
ive replaced upper balljoints on a 2000 expediton with 101,000 .
Jan 5, 2006 at 4:25 AM
CBSONGMAN
Thanks for the response, I guess that was my question: At what point can one expect them to wear out under normal driving conditions?
Jan 5, 2006 at 5:32 AM
DEARDEVA
my 1997 Explorer had both upper and lower ball joints replaced at 120,000 miles...
Jan 5, 2006 at 8:29 AM
SMOKINFLOYD4.3
  • 56 POSTS
really, it all depends on the driver and how well you maintain your vehicle
Jan 5, 2006 at 9:52 AM
GODBEAR839
  • 77 POSTS
I didn mine on a 98 f-150 2000 miles later than you so i would say that is about typical.Make sure you either get lifetime warranty ones or ones with grease fittings most are lifetime and at least you won't have to pay for the parts again.
Jan 6, 2006 at 3:19 AM
Suggested Repair
Ball joint replacement around 85,000–87,000 miles is typical on a similar 1998 F-150. When replacing, use lifetime-warranty ball joints or joints with grease fittings so the parts do not have to be paid for again.
Conversation Summary
The owner of a 1998 F-150 with 85,000 miles asked when front ball joints and tie rods normally wear out under ordinary driving. Other owners reported upper ball joint replacement at about 101,000 miles on a 2000 Expedition and both upper and lower ball joints at 120,000 miles on a 1997 Explorer, and noted that wear depends on driving and maintenance. An expert who replaced ball joints on a similar 1998 F-150 about 2,000 miles later said that timing is typical and recommended lifetime-warranty parts or joints with grease fittings.
Discussion summary
F150 Ball Joints
The owner of a 1998 F-150 with 85,000 miles asked when ball joints and tie rods should normally need replacement. Replies offered replacement mileages from several trucks and SUVs.
Reported outcome: No inspection findings or replacement on this truck were reported.
Anecdotal replacement mileages do not establish a service interval or demonstrate that these parts were worn.
Read the original discussion
