ball joint
MICHAEL SR
I am attempting to replace a left lower ball joint and would like to know if I need special tools and what the difficulty is in doing this is this a press in or bolt in any help you give will be appreciated.
thank you mike
Nov 6, 2007 at 9:23 AM
MERLIN2021
  • 17,250 POSTS
You'll need a ball joint press, looks like a big c-clamp, with tubes and cups to match the ball joint size. If you try to hammer them, you may damage the control arm. Make sure you get the new one started straight!
Nov 6, 2007 at 9:30 AM
