Aiming headlites
YOUNG
HI all..Sorry for my stupidness, but I have a 1996 Ford Ranger. I know I asked before, but I had the wrong year for my truck. ( I havent had it long) So, how do you aim the lites on this little beast? :oops:
Jan 10, 2006 at 10:51 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Obtain the manufacturer's procedure for the installed headlights, including vehicle setup and beam references, or have a shop set the aim with suitable equipment.
Guidance references and applicability
Source: This question and its visible discussion, including any clearly labeled editorial corrections. Owner reports are distinguished from other participants' experiences. Follow-up guidance is not a confirmed diagnosis. HELLA: Headlamp adjustment https://www.hella.com/techworld/en/technical/automotive-lighting/headlight-adjustment/ General aiming and vehicle-setup background; use specifications for the installed headlamps.
Read the replies · Discussion summary and reported outcome
PALCO
  • 83 POSTS
2CarPros editorial correction - October 12, 2026
The earlier six-foot wall-aiming measurements have been withdrawn because they were not verified for this Ranger. Use the manufacturer procedure for the actual headlamps, including the required vehicle setup, aiming distance and beam reference. If that information or suitable equipment is unavailable, have a shop set the aim. Arbitrary vertical or sideways offsets can reduce visibility or create glare for other drivers.
Jan 10, 2006 at 12:25 PM
CHOFFMAN41
  • 11 POSTS
It could have a hex shaft that sticks up behind the headlight. Takes an oddball socket like a 5mm hex or something like that...
Jan 10, 2006 at 2:58 PM
Discussion summary
Aiming headlites
The owner asked how to aim the headlights on a 1996 Ranger. Replies offered uncertain adjuster descriptions and generic wall-aiming measurements.
Reported outcome: No adjustment result was reported.
The unverified six-foot aiming measurements have been withdrawn. This discussion does not establish the correct adjuster tool or aiming dimensions for the truck.
Read the original discussion
