2007 Chevy Impala Remot Entry Will Not Work
57,250 MILES • 6 CYL • FWD • AUTOMATIC
MAF68
The remote lock, trunk and horn buttons on both of our rmotes will not work. The locks and trunk release fine from inside the car. Also, all 4 of the tire pressure sensors are reading blank.
Mar 7, 2009 at 4:46 AM
IMPALASS
  • 3,112 POSTS
Hello –
Please tell me if your model is the LS, LT, LTZ or SS. Also your engine size in liter and the 8th digit of your VIN.
Next, did this just start all of a sudden or did you change car or remote batteries?
Please go to Auto Zone (AZ) or O’Reilly’s (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery and alternator.
Mar 7, 2009 at 11:05 AM
