2005 Chevy Impala
71,775 MILES • 6 CYL • FWD • AUTOMATIC
TRIGGERSPRIDE
my speedometer is geting stuck and people tel me is the speed censor . how can i check if that is true?
Jan 9, 2009 at 5:20 PM
BLUELIGHTNIN6
  • 16,542 POSTS
This is a very common issue with the '05 Impala's . The stepper motor for the speedometer has a broken gear in it, causing unpredictable operation. If the odometer is still working, then the speed sensor is OK. Instrument cluster needs repaired or replaced.
Want to save some green and replace this component yourself? Just ask and I shall post instructions for you.
Hope this helps..
Thanks for using 2carpros.com !
Jan 9, 2009 at 5:34 PM
