2003 Chevy Impala Overheating
CCHANCELOR
  • 2003 CHEVROLET IMPALA
Engine Cooling problem
2003 Chevy Impala 6 cyl Two Wheel Drive Automatic
I noticed the temp gauge showing hot checked the radiator and there was dark brown mud under the cap and was low of coolant. I cleaned the gunk out of the top and top it off. Problem persisted until the water pump went out, replaced water pump, disconnected hoses and ran water through the radiator until it was clear(i realize this is not the proper way to flush the radiator)also ran water through the motor---prob persist brown mud and overheating. Replace radiator and thermostat and used (i believe it was) johnsen radiator flush, cleaned out overflow bottle. Still overheating but no more mud. Heater not blowing hot air.
Thursday, September 23rd, 2010 AT 10:45 AM
RENAUDTN
  • 636 POSTS
When your vents don't blow hot air it can be the sign of a clogged heater core. Given all the " œmud' problem you had with your radiator, I'm guessing your heater core has the same problem. Flush the heater core and see if it helps. Make sure you get all the air out of the cooling system too.
Friday, September 24th, 2010 AT 2:25 PM
