Engine misfiring and flooding and will not run at all?
TINYGIRL72
  • 2003 CHEVROLET IMPALA
It started out just quitting and then it started missing and flooding and will not run at all. The heat/ coolant sensor has been changed, also the air filter and the thermostat. Cardinal chevrolet checked the security system, the fuel pressure, fuel sample, they were OK. We don't Know what else it could be. Do you have any ideas?
Tuesday, March 16th, 2010 AT 12:33 AM
More than likely you have leaking injectors. When the checked the fuel pressure what was the actual PSI?
If you don't know, can we re-run the check and find out when you turn the key on how long the fuel pressure holds.
I suspect it will build the proper pressure but then leak down quickly and then level out. This points a leaking injector.
Then we need to pull the plugs and find out what they look like and see if they show signs of excess fuel.
I suspect they will which at that point we need to replace the injectors.
https://www.2carpros.com/articles/how-to-replace-a-fuel-injector
Please see below for the detail on what the plugs look like and let us know what you find with this.
Thanks
Friday, September 24th, 2021 AT 4:01 PM
Related Engine Not Running Content
