Heater problem
2003 Chevy Impala 6 cyl Two Wheel Drive Automatic
My heater won't blow air, I checked fuses and all are good. What's next to check or what can it be?
Sunday, March 29th, 2009 AT 5:26 PM
RHALL77
MECHANIC
Try tapping on the blower motor and see if it will start working. If not, sounds like your blower resistor may have gone bad. It is located by the blower motor. Remove it and see if it look burned. The blower is under the dash on the passengers side
