Friday, May 8th, 2009 AT 7:52 AM
My car has been overheating for about a month. It will be fine then all of sudden jumps up and says "hot coolant temp". Then after a couple minutes or so it will go back down. I have changed the thermostat, the timing cover gasket and the bypass hose (which had two tiny holes in it) and it is fine for awhile and then right back to overheating. I would open the cap and usually run it until all the air/air bubbles would stop and then put cap back on. Well. Now all I get out of the filler tube is steam and it was the temp gauge will not come down off of "hot coolant temp". What else could I be missing? When I had the timing cover gasket replaced and the bypass hose. They did all that already. So I am still at square one of why it still jumps to "hot coolant temp" and now will not come back down. What else could it be? Somebody told me the water pump. Could that cause it or no? I change water pump radiator hoses the thermostat radiator and put engine block sealant and the temp Gage still goes up and down sometimes when the Gage goes down I get heat then when the Gage goes up I lose heat
