2003 Chevy Impala
2003 CHEVROLET IMPALA
JERMAI07
  • 6 POSTS
2003 Chevy Impala V8 Automatic 100000 miles
I have a 2003 chevy impala. My car has leaks coolant and get hot. I got my head gasket replaced and i drove it and it sounded like a motorcyle engine. The car still gets hot and i saw a leak near the water pump. My car went to the off position while i was driving so i had to turn back to the on position. Can you tell me whats wrong with my car?
Sep 21, 2009 at 5:31 AM
  • 110,244 POSTS
I need you to check something. On the water pump, there is a weep hole. Is is aprix 1/4" in diameter. Check to see if that is where the coolant leak is coming form.
Exactly what size engine is in the car?
Sep 21, 2009 at 3:00 PM
JERMAI07
  • 6 POSTS
i made a mistake on the type of engine, it is a v6. The engine size is 3.8 and yes it almost that size coming from the watere pump.
Sep 22, 2009 at 2:39 AM
  • 110,244 POSTS
Did you check the weep hole on the pump?
Sep 22, 2009 at 3:15 AM
JERMAI07
  • 6 POSTS
yes i checked the weep hole in the pump.
Sep 22, 2009 at 4:32 AM
  • 110,244 POSTS
Was there any evidence of a leak?
Sep 22, 2009 at 6:33 AM
JERMAI07
  • 6 POSTS
the whole and leak has been fix but it still overheats and has a clicking noise. can you tell what is it now?
Sep 25, 2009 at 6:04 AM
  • 110,244 POSTS
HAs the thermostat been replaced and the cooling system serviced? If so, and it continues to overheat and the fans are working, have the head gaskets checked. You will need to have compression tested.
Sep 25, 2009 at 6:36 AM
JERMAI07
  • 6 POSTS
the thermostat was replaced before i got a new head gasket put on. Could it be that the head gasket wasnt put on properly? My car is currently in the repair shop so here is my number (804) 451-5300 and if you need to contact the shop personally to ask question here is there number (804) 458-0880 or (804) 452-0444.
Sep 26, 2009 at 4:58 AM
  • 110,244 POSTS
Hi:
The only thing left is a plugged radiator or something was done wrong. However, considering it is doing the same thing, I would say the same problem still exist. Thus, the head gasket didn't fix it.
Wait to see what they say on Monday. It's 12:47AM here so I can't call at this time. Let me know what you find out.
Sep 26, 2009 at 4:47 PM
JERMAI07
  • 6 POSTS
Will getting my motor replaced with another motor fixed this problem?
Sep 28, 2009 at 10:02 AM
  • 110,244 POSTS
Not if the radiator or cooling system is plugged. I would have that checked. You may need to "rod out" the radiator because a regular flush may not do it.
Sep 28, 2009 at 2:10 PM
