2001 Chevy Impala Turn Signal
KEHYSELL
  • 2001 CHEVROLET IMPALA
  • 6 CYL
  • 70,000 MILES
My 01 Impala has a turn signal issue. Most of the time when I turn on the signal (left or right) I get a buzzing sound instead of the signal working. The lsignal light stayes solid when the buzzing begins.
Thursday, May 21st, 2009 AT 4:26 AM
2CARPRO JACK
  • 11,533 POSTS
Do the hazards work? Sounds like the flasher is going out
Thursday, May 21st, 2009 AT 8:11 AM
KEHYSELL
The hazards are the same way. When turned on it just buzzes.
Thursday, May 21st, 2009 AT 11:17 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like it is the flasher.
Thursday, May 21st, 2009 AT 12:59 PM
KEHYSELL
Thanks Jack, where could I find it and is it hard to replace?
Friday, May 22nd, 2009 AT 4:33 AM
2CARPRO JACK
  • 11,533 POSTS
The hazard switch is the flasher as well, it is integrated.I cant find any specific instructions on replacing it in my software.I would suggest getting it and seeing what you are dealing with, to do theturn switch th esteering wheel has to come off which requires a pulller. Also need to disconnect neg bat and wait about 10 minutes before the air bag can be removed. The hazard switch may be replaceable by removing the top and bottom column covers.
Friday, May 22nd, 2009 AT 7:31 AM
