2002 Chevy Impala Headlights and tail lights flicker, click
ERICJCHRIS
  • 2002 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 140,000 MILES
Recently I noticed that my headlights and tails lights flicker accompanied by a clicking sound coming from the front passenger side of the car. I can override these symptoms by manually turning on the headlights by pulling the headlight knob on the dashboard. However, if the manual switch is pulled, then I shift the car in reverse, the exterior lights begin flickering immediately along with the clicking sound. The clicking and flickering of the lights seems to be synchronized. The car runs fine with the exception of the issues listed above. What are causing these issues and how can they be addressed?
Saturday, February 27th, 2010 AT 10:29 AM
JDL
  • 16,098 POSTS
Hi, thanks for the donation. There are relays located above the passenger side fuse fuse box. Feel of the relays when the problem is ongoing, you should be able to feel the vibrations as far as which one is clicking. Hopefully the relays are labebed.
Do you have a voltmeter on the dash, does it react to the clicking? If so, check the charging system. There are manufacturer specific codes for the charging system.
Saturday, February 27th, 2010 AT 2:57 PM
