My temp gauge just quit but it is still heating. Would it be a sending unit or would it be the gauge itself?
Wednesday, January 30th, 2008 AT 8:10 PM
BMRFIXIT
MECHANIC
I would start with the sending unit
and it wire
Wednesday, January 30th, 2008 AT 8:24 PM
PATCHOMAN55
MEMBER
Is the sending unit electronis or is it the one that screws into something. I did not get a check engine light.
Thursday, January 31st, 2008 AT 9:24 AM
BMRFIXIT
MECHANIC
The correct way is to have it hooked to a scanner and read engine data
if it showing you have a good engine temp then you move on to check the cluster gauges
and check the BCM
most I ve seen is the thermostat
but usually that follow with check engine code 128 or so
or the coolant level module stuck.
But also check under hood around the thermostat housing for the temp switch and make sure is OK
