Recently we had a lot of work done on my daughter's car. We had a new radiator installed, hoses, water pump, head gaskets, thermostat, etc. Last night she arrived at my house after driving all day and the temperature gauge had stayed right in the middle where it should be. She parked the car for about fifteen minutes and when she restarted the car, the gauge went all the way over to 260. We opened the hood and the engine was clearly not overheating. When we turned off the car the gauge did not go down to the lowest setting. We let it sit for about ten minutes and restarted the car. Then the gauge went past 260 into the area of black beyond. When we turned off the car, the gauge went back to 260 and was erratic every time we started the car. The warning sign has never come on to indicate overheating. We are thinking this is a gauge malfunction (a short?) And have learned that it is fairly costly to remove the dash and send it out to be repaired. Maybe we do not have a choice. Any thoughts?
SPONSORED LINKS
Monday, April 6th, 2009 AT 11:51 AM
