2001 Chevy Impala Power Windows
2001 CHEVROLET IMPALA
95,000 MILES • 6 CYL • FWD • AUTOMATIC
BLAINE989
My driverside window goes down but it doesnt come back up, but every other window woks perfectly.Is it the motor, or the wiring?
Jan 9, 2008 at 11:43 AM
CLICKMYSPACE
The wiring harness running from the body of the car into the driver side door are made extremely short. My windows started acting up. First the driver side and then eventually all the other doors. I google searched the problem and came to a site where it was suggested that I pull the rubber cover back from the wires and sure enough, that was the problem. However, at first I thought I had hit a dead end. I really had to finger through the cluster of wires before finding there was a black wire that had snapped. As for fixing it, my husband had a device that clamped to one end and then to the other, pinching into the rubber but not cutting through the copper. It was just long enough to give it the extension it needed. I tested the window and it worked like new! It was so easy ... and cost me nothing (thanks to my husbands wire clamp thing). If this doesn't help, you might look into a worn or defective power window switch. I'd go the cheapest route first though.
Jan 12, 2008 at 8:01 AM
MUDDYBLAZER
[quote:e964de68ea="clickmyspace"]The wiring harness running from the body of the car into the driver side door are made extremely short. My windows started acting up. First the driver side and then eventually all the other doors. I google searched the problem and came to a site where it was suggested that I pull the rubber cover back from the wires and sure enough, that was the problem. However, at first I thought I had hit a dead end. I really had to finger through the cluster of wires before finding there was a black wire that had snapped. As for fixing it, my husband had a device that clamped to one end and then to the other, pinching into the rubber but not cutting through the copper. It was just long enough to give it the extension it needed. I tested the window and it worked like new! It was so easy ... and cost me nothing (thanks to my husbands wire clamp thing). If this doesn't help, you might look into a worn or defective power window switch. I'd go the cheapest route first though.[/quote:e964de68ea]
the master switch go bad and cheap to fix you can get one off ebay and change out very easy
Jan 12, 2008 at 10:43 AM
