Is this a camshaft sensor issue or another type of censor issue? I'd like to visit that before putting in a new transmission or some other major repair.
2000 Chevrolet Impala Bogs at Highway Speed
Oh, and as for the motor vac, I am pretty convinced that was a complete sham, so no wonder you laughed at that...
Do tell, what is up with the clown pic?? That is pretty funny!
Suggested Repair
Before replacing the transmission, inspect and replace the mass airflow sensor and oxygen sensors, which are due around 100,000 miles even without a warning light, and perform a tune-up.
Conversation Summary
A 2000 Chevrolet Impala with 111,000 miles bangs into gear under acceleration and later bogs or feels starved for air around 60-65 mph, with fuel economy dropping from about 379 to 290 miles per tank. Adding transmission fluid and an engine cleaning only slightly helped, and the air filter is clean. The expert identified the mass airflow and oxygen sensors as the main items affecting mileage and bogging, recommended replacing the oxygen sensors around 100,000 miles even without a warning light, and advised a tune-up. The owner planned to replace both sensors.
