1994 Chevrolet Corvette Balancer Removal Fix
BELFIGLIOVAL
i have a 1994 LT-1 corvette auto trans with 94,000 miles, heres my question i am trying to remove the harmonic balencer { vibration dampener} theres not much room, do i need to move the steering rack first? or try to raise the motor? thanks for any help.
Aug 31, 2007 at 5:35 AM
  • 75,988 POSTS
[quote:1123164ed2="belfiglioval"]i have a 1994 LT-1 corvette auto trans with 94,000 miles, heres my question i am trying to remove the harmonic balencer { vibration dampener} theres not much room, do i need to move the steering rack first? or try to raise the motor? thanks for any help.[/quote:1123164ed2]
You can use a long breaker bar with the correct socket and wedge it determine the direction and crank it over it'll break loose.
Aug 31, 2007 at 11:01 PM
BELFIGLIOVAL
[quote:cc54fe8ab6="rasmataz"][quote:cc54fe8ab6="belfiglioval"]i have a 1994 LT-1 corvette auto trans with 94,000 miles, heres my question i am trying to remove the harmonic balencer { vibration dampener} theres not much room, do i need to move the steering rack first? or try to raise the motor? thanks for any help.[/quote:cc54fe8ab6]
You can use a long breaker bar with the correct socket and wedge it determine the direction and crank it over it'll break loose.[/quote:cc54fe8ab6] [[-- the bolt is already is already out , im talking about removing the balencer itself, as there is no room, raise engine or move steering rack??
harmonic balencer removal ?? that was your Q-you have to raise the engine to get clearance
Sep 1, 2007 at 3:00 AM
Suggested Repair
With the crankshaft bolt already removed, raise the engine to gain clearance to pull the harmonic balancer. Moving the steering rack is not the recommended approach.
Conversation Summary
The owner of a 1994 Chevrolet Corvette LT1 with an automatic transmission asked how to remove the harmonic balancer in a tight space, specifically whether to move the steering rack or raise the engine. After clarifying that the crank bolt was already out, the expert said the engine must be raised to get clearance.
