2001 CORVETTE BULB REPLACEMENT
FTRWSO
I own a 2001 Corvette ZO6 and the right front running light/turn signal bulb is out (which means I lose my turn signal on the right side completely). The owner's manual tells you how to replace the rear bulbs but only says "see dealer" for the front. How do I get to the bulbs under the headlights in the front so that I may replace the faulty bulb? Thanks.
Jul 15, 2006 at 2:12 AM
MIKEYBDMAN
  • 623 POSTS
Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the front fascia lower closeout panel.
Release the brake caliper cooling duct from the front fascia, then reposition the duct.
Remove the appropriate socket from the lamp assembly.
Remove the bulb from the socket.
Install the bulb to the socket.
Install the socket to the lamp assembly.
Position the brake caliper cooling duct to the front fascia and push the duct toward the fascia to secure.
Install the front fascia lower closeout panel.
Lower the vehicle.
Jul 15, 2006 at 7:57 AM
