1973 Chevrolet Corvette Front Brakes Lock
JAK
I have a 73' Covette w/56,000 miles. Car has been in storage for the past 26 years. I replaced the rotors
but the front brakes are locking up when I go approx.
8 or 10 miles. I bled off the line to release the car so I
could drive it back home but it would continue to seize
up and I would have to repeat this every 2 miles or so.
The rear brakes work ok just the fronts are giving me
problems. any help would be apreciated.
Oct 6, 2007 at 10:43 AM
MERLIN2021
  • 17,250 POSTS
If the car sat for 26 years, you'll probably find you need new calipers...Brake fluid is hydroscopic, meaning it absorbs moisture, and it does this even thru the rubber seal and dust boot. Over timee the black paste, or sludge builds up behid the piston so it cant slide back in. I would replace all seals and ckeck all steel brake parts before going for a ride in a car that sat that long!
Oct 6, 2007 at 3:05 PM
Suggested Repair
Replace the front calipers and all brake seals. Moisture-contaminated fluid can leave sludge behind the pistons so they cannot retract. Also inspect all steel brake parts before driving a car that sat for many years.
Conversation Summary
A 1973 Chevrolet Corvette stored for 26 years has front brakes that lock up after about 8 to 10 miles, even after the rotors were replaced. Bleeding a line temporarily frees the brakes, while the rear brakes work normally. The expert says long-stored fluid absorbs moisture and sludge can prevent caliper pistons from sliding back, so the calipers and seals should be replaced and all steel brake parts checked.
