1974 Chevrolet Corvette Hot Stall
BAMBOOWEST
Hi, any help would be appreciate it! My 74 Corvette stalls when engine is hot? Example, I drive it for about 20 minutes locally in 80 degree weather and then turn off engine and sits for about an hour. I get into the car and start to drive, then the engine starts to shake slightly while at traffice light and all of a sudden it cuts off while in motion. I try to start it again and pump the gas pedal many times and bearly got it started again which engine shakes quite a bit. It continues to shake and dies down again after few miles. But in the morning when engine is cold it seems to drive fine. Can anyone help me?
JC
Oct 18, 2007 at 1:50 PM
  • 75,988 POSTS
When was it last major tune-up?
Could be a choke adjustment problem or vacuum leak and A/F mixture and Curb idle adjustment. Check the PCV and EGR valves.
Won't hurt to check the fuel pump pressure-fuel filter okay?
Oct 18, 2007 at 3:36 PM
Suggested Repair
Check for a needed tune-up, choke adjustment, vacuum leak, air-fuel mixture, and curb idle. Also inspect the PCV and EGR valves, fuel pump pressure, and fuel filter.
Conversation Summary
A 1974 Chevrolet Corvette runs fine when cold but shakes and stalls after the engine is hot and has sat briefly. The expert suggested checking the last major tune-up, choke adjustment, vacuum leaks, air-fuel mixture, curb idle, PCV and EGR valves, fuel pump pressure, and fuel filter.
