1975 Chevrolet Corvette Hard Start
RICK BUTLER
I have a 75 corvette L48-350. I have changed the starter/the battery,and had the altanator checked. The problem I have is when I try to dtart the car it acts like it has a bad solanoid.I can jump start the car and it run fine until it is turned off.Then it has to be rejumped. This has me stumped because I have changed or tested wverything in the starting system.
Apr 21, 2007 at 4:13 PM
  • 75,988 POSTS
[quote:3f5e8d95cc="rick butler"]I have a 75 corvette L48-350. I have changed the starter/the battery,and had the altanator checked. The problem I have is when I try to dtart the car it acts like it has a bad solanoid.I can jump start the car and it run fine until it is turned off.Then it has to be rejumped. This has me stumped because I have changed or tested wverything in the starting system.[/quote:3f5e8d95cc]
Got to make sure that purple wire while disconnected from the solenoid is receiving full battery voltage when key is in start position.
And triple check all connections involved in the starter control circuit.
Apr 21, 2007 at 5:34 PM
RICK BUTLER
you are correct that it was a connection problem,however nothing was lose.the red wire going into the altanator was broken inside the plug,thus giving a bad connection.the way i found this was i went to retest the altator it came apart.iwill let you know what happens after i change the plug today.
Apr 24, 2007 at 12:29 AM
Suggested Repair
Repair or replace the broken red wire and plug at the alternator. Also confirm the purple solenoid wire has full battery voltage with the key in start and recheck all starter control circuit connections.
Conversation Summary
A 1975 Chevrolet Corvette L48-350 would not crank and acted like a bad solenoid, though it ran normally after a jump until shut off. The starter, battery, and alternator had already been replaced or tested. The expert advised checking the purple solenoid wire for full battery voltage in the start position and inspecting starter control connections. The owner then found the red wire broken inside the alternator plug and planned to replace the plug.
