2000 Chevrolet Corvette Climate Display Dim Fix
COTA252
2000 corvette 69k mi display for climate control is not visible during the day and very faint at night . looks like it doesn't work if you don't look real hard just bought the car is this an easy fix if so how
Dec 29, 2006 at 8:01 AM
  • 55,758 POSTS
There is a light behind the liquid crystal display that needs replacing.
Feb 16, 2007 at 6:35 AM
COTA252
[quote:f3c0e6435d="2CarPro Ken"]There is a light behind the liquid crystal display that needs replacing.[/quote:f3c0e6435d]
is this something a average home shadetree can do
if so can you get the part from gm
Feb 21, 2007 at 2:19 AM
REAL_LUCKY1
Yes it's an easy fix!
My 2002 had the same problem until I fixed it with these instructions. Took me only 90 mins and it works like new.
Good Luck
Real_Lucky1
Apr 15, 2007 at 4:19 AM
Suggested Repair
Replace the backlight behind the climate control liquid crystal display. Owners report this is a straightforward DIY repair that can take about 90 minutes on a similar Corvette.
Conversation Summary
The owner of a 2000 Chevrolet Corvette said the climate control display is not visible in daylight and very faint at night. An expert advised that the light behind the LCD needs replacing. Another owner confirmed the same issue on a 2002 was an easy fix that took about 90 minutes and restored normal display brightness.
