1996 Chevrolet Corsica P0125 CEL
ADIB24
i have a 1996 corsica, milage 100000, 2.2L auto trans.,, engine was replaced before i bought it.check engine light is on,error code is p0125 (coolant temp take too long to reach closed loop). when light is on ,the fan stays on, sometimes light goes out (very rarely), and the fan acts normal. i am not sure which comes on first,light or fan (i think fan kicks on first). .i change fan sensor, i thought it fixed it,but because the battery was disconnected,the light goes off and fan is fine, but after driving about 40 miles,fan kicks on and light comes back on.the reason i need this fixed because it will not pass inspection.
Jun 18, 2007 at 7:17 PM
SERVICE WRITER
  • 9,123 POSTS
Thermostat is probably not working right. That is stuck open.
Jun 19, 2007 at 2:28 AM
LEGITIMATE007
  • 5,121 POSTS
[quote:2e7e85a654="adib24"]i have a 1996 corsica, milage 100000, 2.2L auto trans.,, engine was replaced before i bought it.check engine light is on,error code is p0125 (coolant temp take too long to reach closed loop). when light is on ,the fan stays on, sometimes light goes out (very rarely), and the fan acts normal. i am not sure which comes on first,light or fan (i think fan kicks on first). .i change fan sensor, i thought it fixed it,but because the battery was disconnected,the light goes off and fan is fine, but after driving about 40 miles,fan kicks on and light comes back on.the reason i need this fixed because it will not pass inspection.[/quote:2e7e85a654]
I would say your next move should be your "ECT" engine coolant temperature sensor. It is more than likely sending a week signal to the computer , thus not allowing it to go into closed loop . let me know what happens.
legitimate007
Jul 28, 2007 at 2:26 AM
Suggested Repair
Check the thermostat for being stuck open, and test the engine coolant temperature (ECT) sensor for a weak signal that keeps the engine from entering closed loop.
Conversation Summary
The owner of a 1996 Chevrolet Corsica with a previously replaced engine reports a check engine light and code P0125, meaning coolant temperature takes too long to reach closed loop. The cooling fan stays on while the light is on. Replacing the fan sensor and disconnecting the battery cleared it temporarily, but the fan and light returned after about 40 miles. One expert says the thermostat is likely stuck open; another recommends checking the ECT sensor.
