1990 Chevy Corsica Oil Light Flickers
BRADEN
i have a 1990 chevy corsica 2.2l 4cyl it has 141900 miles while im driving the oil light flickers it has oil is there any way i can ckeck to see if the oil pump is working or is there any thing else that it could be
Jun 6, 2007 at 9:16 AM
E40WATER12
  • 522 POSTS
Is the oil oil level correct level?. Also could have a bad oil sending unit switch. Is youre motor making any kind of knocking noises?.
Jun 9, 2007 at 11:08 AM
BRADEN
GOT IT FIXED IT WAS WRONG VISCOSITY OIL THANK ANY WAY
Jun 24, 2007 at 11:44 AM
Suggested Repair
Use the correct oil viscosity for the engine. Also verify the oil level, listen for knocking, and check the oil pressure sending unit if the light still flickers.
Conversation Summary
A 1990 Chevrolet Corsica 2.2L with about 141,900 miles had a flickering oil light while driving even though oil was present. The expert asked about oil level, knocking noises, and a possible bad oil sending unit. The owner later reported the problem was fixed by using the correct oil viscosity.
