When the airbag is lit, the system is inactive. Should you get in a front end crash, the airbag/s will not deploy leaving you unprotected. I would call the dealer and ask them to run your vehicle's VIN through their system. It could be that there was a recall for the safety restraint system on your car in which case the repair will be free of charge to you. If there are no recalls and no warranty coverage for safety restraint systems, (sometimes there is extended coverage on such systems) then take it to a qualified shop if you're more comfortable with that. Just make sure before you go to the shop that they have the scan tool and software to tap into the safety restraint module for diagnostics. Usually a lit airbag can be attributed to faulty wiring, crash sensor behind the front bumper, bad connection between the airbag and lower part of the steering column, or a faulty airbag module.
SPONSORED LINKS
Monday, August 24th, 2009 AT 10:01 PM
