1996 Chevy Corsica ABS light
1996 CHEVROLET CORSICA
MOMMACAT1062
Brakes problem
1996 Chevy Corsica 6 cyl Automatic 155000 miles
My ABS light has been coming on...I've taken it to have a diagnostic test done, but they say they're not getting a code. What does this light mean and what can I do to make it go off?
Feb 23, 2010 at 3:25 AM
ROYGAM
i had the same problem,what that you need to do is simple.
under the steering culman you`ll find a brown,blue or pink plastic squere electronic module.
what that you need to do is to take it of,and replace it.
this module controlls the ABS,dome light,and the sounds that comes on when you forget the keys in the ignition switch.
good luck!!
Feb 28, 2010 at 12:39 PM
AUTOMD
  • 50 POSTS
maybe a faulty sensor or ABS malfunctioning. Try to have a testing and changing your car's faulty relay it may fix the problem.
Mar 2, 2010 at 3:25 AM
