1994 Chevy Corsica 94 Corsica no start
DRAU
  • 1994 CHEVROLET CORSICA
  • 4 CYL
  • 189,201 MILES
I have fuel and spark at the plugs. Engine cranks but will not fire. I have replaced the icm. Could the crank position sensor cause ignition timing to be off?
Sunday, January 24th, 2010 AT 7:41 PM
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Sunday, January 24th, 2010 AT 7:59 PM
DRAU
I pulled the front cover and the crankshaft to camnshaft timing is correct. No timing marks at the crank pulley. I am thinking of marking tdc on the crank pulley to see where #1 spark is in relationship to tdc.
Wednesday, January 27th, 2010 AT 6:22 PM
Good idea also if its a distributor system-make sure the rotor is pointing the no.1 cap tower
Wednesday, January 27th, 2010 AT 7:21 PM
