If you are getting fuel and spark (spark should be a blue snapping spark), then use a noid light to check fuel injectors.
Disconnect injector connector and install noid light, crank engine and noid light should pulse, if noid light does not light, then check fuel injector fuse.
SPONSORED LINKS
Tuesday, February 2nd, 2010 AT 9:23 AM
