1994 Chevy Corsica
SUMMERBREEZES
  • 1994 CHEVROLET CORSICA
  • 6 CYL
  • 263,000 MILES
Hello, I have a 1994 Corsica that overheats and white smoke comes out the exhaust. I changed the water pump as well as the thermostat, but it continues to overheat. What do you suggest I do?
Monday, October 20th, 2008 AT 1:33 AM
  • 109,896 POSTS
Hi:
The white smoke is an indicator that the car needs a headgasket replaced. Coolant gets into the combustion chamber and burns white. This is most likely causing the car to overheat.
Have the engine checked for a bad headgasket. If I'm wrong and it's fine, let me know and I'll walk you through how to identify the problem.
I hope this helps.
Sunday, October 26th, 2008 AT 1:27 AM
