It in the right hand side of the motor if you seat in the car.
You need to take of the acssories belt out, then you need to take of 4 screws from the water pump wheel/
after you take it off you`ll see 5 screws
that you need to take off as well/
take the new water pump, put a new gasket bolt in the 5 screws, then put in the round plate put the 4 bolts than put the belt, start the car fill water inside the system, take off the air from the system, check for no licks and youre set.
Good luck
SPONSORED LINKS
Sunday, January 31st, 2010 AT 5:53 PM
